Come across a few problems this evening. Hoovered my car to fine the drivers footwell carpet/ mat wet. Though ok, will have to investigate, sunroof drains fine also does the gutter bit infront of the bonnet. Ok I thought. Only to pop into town. Lock the car and realise the lights won't turn off! I messed around with the lights switch, even took it out and disconnected the light switch from wiring. Still on. Turn car on off. Still on. Only way to turn them off ( main and sidelight) is me having to disconnected the battery. They came on if I reconnect the battery. Hence I'm leaving it disconnected. Also forgot to mention I have the auto light retro fit jobbie. Any suggestions??
