1 - 8 of 8 Posts
Can anyone help, I need drivers side rear quarter glass for a 3dr. I was told the rubber seal is in between the panes so have to replace the whole thing.
Does anyone know where I can get this? Also is it the same as any mk4 glass or is the tint different?
Thank you in advance
I would try TPS to get the correct OEM part with the blue tint. Don't know if other MK4s have the same tint.
Markiv not green tint or that only for the windscreen?
Regards
Vrt
As far as I know MK4s and early MK5s are blue and later MK5s are green
Irrespective if it's green or blue, TPS will supply the glass as per the original build off the VIN / Reg No.
Reactions: technique
1 - 8 of 8 Posts
