1 - 20 of 31 Posts
Ive noticed today on tickover that my r feels like its missfiring yet it drives fine with no fault codes ?? Is it just a common v6 thing ?
No the idle should be smooth. Normal idle is around 600rpm.
Administrator
Mine feels slightly lumpy on tick over sometimes its not that noticeable but is there , I thought it was because of my cams as its extremely smooth on driving even smoother that a fiesta a drive with 800 miles (mine felt newer too)
No mine is noticable , im going to change the plugs and fuel filter but my guesses are its a coil pack thats starting to fade . ..hope it aint the flywheel
Have the coilpacks been changed in the last couple of years as part of the coilpack "recall" that affects all R32s upto around 2007?
Administrator
themainlegend said:
Get the throttle body cleaned up!!! Surprising how much grime builds up in there!!!
Show me tomorrow what and where it is
Apparently it has , I phoned vw about two week ago and tried to get a mechatronic recall but they checked my vin and said it only had the coils two year ago and there was no more
Senior Citizen
Take the battery off for 10 minutes the. Reconnect and it cycles the throttle body to basic settings I believe. I am about to be shot down in flames I bet.
AaronMc said:
Mine has something like this, idle is dead smooth and doesnt fluctuate, but I have a tapping feeling through the floor, both me and passenger can feel it, doesnt go when clutch is depressed either but feels related to flywheel..
This is what mine is like...a broken flywheel sounds expensive to fix!
I wasn't aware of this? If your careful you can clean it without re calibration through VCDS,
My MK4 had a slightly lumpy idle before I did the chains. Discovered it was timed a tooth out. It's much smoother now, both at idle and through the revs.
My mate had a 2008 MK5 DSG from new and that was the same. You could see it rocking about on it's mounts on idle after a good thrash, but it was pretty smooth in the car. None of the VR6s have ever been totally stable at idle like an Audi V6 or BMW 6.
You don't need to do anything to the throttle body when you remove it. The ECU self calibrates the throttle and pedal. MK5s dump the crankcase deposits downstream of the throttle blade anyway.
So if you take it off and clean it there's no re calibration or re alignment via VCDS required?
Mine sits dead level on idle at 600rpm but i to have slight vibration as the engine rocks about, i checked the figures on my timing chain and the blocks came back with positive readings. My car is a DSG, im putting it down to the flywheel myself. Im going to call up to find out about the coilpack change, As a cheaper alternative i will give the plugs a refresh at some point and clean the throttle body but if no luck i will be tempted to change the flywheel at some point.
I have. 06 plate DSG and mine is exactly the same sits dead level at 600RPM but can feel very slight vibration when idling but I have noticed is when in park or neutral i can feel vibration but when I put it in drive with my foot on the brake I can't feel the vibration I am glad someone started a thread on this as I was wondering what it is myself
Maybe a silly questions but do both DSG & Manaul sit idle at 600rpm.
Mine sits higher its a manual ?
Exactly the same,
Moment my car goes into D, no more vibration at all but in park and neutral i feel the vibration. My guess is the flywheel as when we ran a diagnostic the crankshaft position sensor flagged up on VCDS, but no dash lights. This indicated that maybe the flywheel is nearing the end of its life as a slight imbalance at one point may have triggered this CEL.
It drives fine otherwise with no power loss but its on the agenda at some point to have the flywheel changed.
Oh dear don't like the sound of that mine is only a very slight vibration my misses who drives the car more than me has never noticed it but I am very picky on things like this I take it it's one of those things that will just get worse and what would the cost be to have a flywheel fitted to a DSG ££££ anyone know
Having looked at the other post on mine you can't see any movement on engine when it's running just very slight vibration when in P when your sat in car
1 - 20 of 31 Posts
