· Mozquito Member
The most simple of mods that I've ever done which has made me smile.
Simply remove the pipe and bung it with a screw, to be 100% i've folded it in half and cable tied it.
There is a valve within the exhaust system that opens up at 3500rpm and increased the depth of sound. I believe these were installed for US/European regulations. However, this is not required in the UK.
If you look under the left rear of the car, you'll see the black rubber/silicone pipe going into the silver actuator value.
Remove the black pipe and bung it, either with a plug, or in my case a screw. To be 100% I've folded it over and cable tied it.
Others recommend then blocking off the valve to reduce anything getting sucked in, although this car has been ran without for some time and no issues.
Enjoy VROOOOM
