I've got them on mine (they are so much better than stock). I've got the rear on the lowest setting and I've removed the rubber spacer lowering it a further 10mm but i have got the rear tie arms. I've got them set midway up front but every now and again I harden them up for the track. I've only played with the front as I had the rear set fairly hard to start with but I'll check when I get it back. :151:
