1 - 6 of 6 Posts
With the PCD being 5x120, I assume you need to use "wobble" bolts to fit to a MK5 which has a PCD of 5x112 and adaptors for a MK4 which is 5x100.
Wobble bolts wont give you 8mm. They will work from jap 5x114.6- 5x112
You will need adapters for either MK4 or MK5
Cheers, just wanted to clarify for any potential buyers. I wasn't sure as it's not actually 8mm from hole centre to hole centre it's 4mm.
Reactions: Andrew.
1 - 6 of 6 Posts
