1 - 4 of 4 Posts
Keep getting caught out leaving my lights on as I have no alarm to warn me when I have left them on and get out Doh! How cn I fix it before have a battery gong flat incident? lol
Usually if your door module is faulty the warning chime wont sound. Does your puddle light and interior lights work when you open the door?
What I did to a Honda is fit a external buzza under the dash and run 2 wires to the door contact switch you can pick a chima up for a local electrical shop for a couple of quid and the wires cost pea nuts give it a permanent live off the side light wire ensure to fit another inline fuse but make sure it's a low amp fuse (5) run the other wire to the door contact switch which automatically grounds when you open the door and if the lights are on it will buzz until you turn your lights off its like a fail safe if anything is faulty on the car it will always buzz if the lights are on
1 - 4 of 4 Posts
