1 - 10 of 10 Posts
Planning on getting the milltek fitted tomorrow, quick question though, from other lads experience will I need to change the gasket where the cat meets the non res pipe?
Cheers for any advise.
themainlegend said:
Get VW gaskets, £16 for a pair. Like the others have said, use some paste on non res pipe to cats then clamp over it. Job done!
Have any of you guys just slid the non res end onto the cat end and clamped or has anyone used the original sleeve that came on the standard system? I didn't see a point as it was a solid fix?
Used holts as suggested.. Works a treat and sets fast
I used a 63mm D clamp only
Cool, that's all I used but there seems to be a slight noise asif it's blowing but I know all joins we're tight and had paste on.
1 - 10 of 10 Posts
