I might be wrong here (as I have a mk5 and am far from a mechanic!) but that could well be a lambda sensor fault. As I understand it, there are four sensors, 2 in front of the Cat and 2 after it. Two are for the branch of the exhaust that goes to bank 1 (cylinders 1,3,5) and the other two are for bank 2 (cylinders 2,4,6). That might more sense that the coil packs if the fault is showing on all the odd number cylinders....
