1 - 11 of 11 Posts
I've tried the search and couldn't find anything but is anyone running 17" wheels on their MK4?
I'm rather taken by these, especially as they clear the front calipers - http://www.neuspeed....ight-wheel.html
I'm just looking to reduce unsprung weight and improve the ride quality as the craters on my local roads are getting beyond a joke now. My local dual carriagways are the concrete variety as well, which are REALLY noisy.
I know a couple of people use 17's as winter wheels. They will be fine obviously if the RR is the same and you will need it slammed to get rid of some arch gap haha
If the RR is the same the arch gap will be the same
Semi-Advanced Member
The only problem (if you even consider it one) us you will have to run big profile tires to keep the RR the same, which might make your car handle a bit worse but should be more comfey...
I mean in general with a 17'' wheel compared to an 18'm an the RR is the same all round
I know what you mean but if the tyre fitted to rhe 17 has a large enough sidewall to match the RR of the 18s then the arch gap will obviously be the same. Although the smaller wheel larger profile tyre doesn't look as good.
Reactions: PaulW
I'm running 17" Porsche Twists on my 1.8T
ET 50 / 55 i believe and 25 mm PCD adapters......
7.5J front and 8.5J rears ........with a tasty 40mm stretch on the rears
They are for sale soon
Wez
Cheers guys
Not too keen on Porsche wheels on VWs, but cheers anyway Wez
Is 225/45/17 not the same RR as 225/40/18 then?
I'm not too bothered about unsightly arch gaps tbh. I've grown out of all that now
1 - 11 of 11 Posts
