Right here goes all of a sudden the R has ended up with a big list of problems
1st off EPC light came on and narrowed it down to brake sender thanks to the forum
2nd speedo stopped and fuel gauge is having a dance up and down but I checked the fuse and checked the connections on the gearbox side and cleaned everything but its still broken.
And the major one is the air con/ heater control head unit control box stopped working so I checked the fuse and it had popped so I changed it and the fans were going on/off all the time and the garage said it's the air con fan but when I removed the key from the ignition every light on the clusters were flashing and then I could smell and eventually seen smoke in the engine bay and the garage said its the big black relay which controls the fans so I removed the box and put the fuse back in and turned the ignition back on and the same again happened
Any ideas towards this.
