Firstly Hello guys new to the R32OC
One of those things I should have done along time ago.
Well Im on here now.
I have a standard Mk4 R32 Black with Black leather interior.
Standard wheels the only recent upgrade was a set of Eibach Pro springs replacing the Snapped standard springs.
All was fine since Ive had it, Been about a year now, maybe longer.
Up until a couple of weeks ago when after a very short drive, went to start it and it refused.
After a couple of trys and waiting it started.
Hooked it upto VCDS and this what it showed.
17746 - Camshaft Position Sensor (G40)
P1338 - 001 - Open or Short to Plus
17755 - Camshaft Position Sensor 2 (G163) / Engine Speed Sensor (G28)
P1347 - 002 - Incor. Correl.
Cleared the above but the G40 kept comin back as a fault.
Anyway stayed fine for another few weeks up until a couple of days ago when after a few local trips it just refused to start.
I was thinking sounds like a fuel problem
Sprayed some easy start hoping this would get it going, But the 32 wasnt having any of it.
Hooked up the VCDS and this is what it was sayin.
As well as the two above faults.
Catalyst System; Bank1
P0420 - 001 Efficency Below Threshold
Accelerator Position Sensor 1/2 (G79/G185)
P1639 - 008 Implausible Signal
Camshaft Position Sensor Bank 2 (G163)
P1391 - 002 - Short to Ground
Intake Manifold Valve (N156)
P1516 - 004 - Open circuit.
Intake Air Temp Sensor (G42)
P0113 - 002 - Signal too High - Intermittent.
Anyway after that shock of having 7 fault codes and reading up of similar problems with starting, I thought maybe fuel pump.
So I managed to disconnect to fuel line coming in and got someone to crank it over and see if the petrol comes through, And what do you know there was petrol pissing out all over the place
So the fuel pumps ok.
Well it was getting dark and seeing as though its on the drive I called it a day.
Any thoughts on this would be greatly welcomed.
I am suspecting either a faulty Oxygen sensor or broken wiring somewhere.
Thanks in Advance
Zaf.
Thanks in Advance
Zaf.
