.:R32OC Resident Pervert
Hi,
Just wanted to know the tyre pressure in PSI for the mk4 .:R32
Thanks James.:)
macdaddy said:
Try this website :
http://www.centauro-owners.com/articles/psibar.html
converts psi-bar and bar-psi.
very useful
I think its about 36 , but use the above to convert if you have the exact bar as i'm going off memory. (i still have to check the fuel flap every time to remind myself)
Thanks ,
I did my tyres up at Sainsbury's and the machine converted it ,But not sure about it when I went down the road.
I brought from ebay a digital tyre gauge.
I will look again on the filler cap and convert it.
Thank you young man.:)
Vintage_Geek said:
IIRC it's 36 Front and 33 Rear. (something like 2.5, 2.3 F/R)
I'm glad you said that, as I've always done 36/34 without even reading the manual. Just did it on what felt right :eek:
Yes, 36psi F , 33psi R are the correct pressures for a mk4. Tyre pressures make a big difference to mpg on the R32 for some reason, so check them regularly.
