I've recently noticed that the rad fans on my R32 make an awful lot if noise! When the car is cold and I start it up the fans kick in straight away, as if the car had been ragged and is red hot!
Is this a normal trait of the Mk5 R32 or is there something not quite right? As I don't remember it doing it and have really only just noticed it!
Sounds like the fan controller which i believe is built into the fans on a mk5, mate of mine has a brand new set boxed if you need em.
Have you got the climate control set on auto?If so fan always kicks in.Try it on econ or off and see if that stops it.
It kicks in on low speed which you can't really hear from inside the cabin. From his description, sounds like they are running on high speed, which points to either a faulty temperature sensor or the fan controller.
he secondary air pump can also make a noise similar to the fans running on cold starts.
Ah rite mine was kicking in at high speed when on auto?As mentioned even when first started, it has stopped since leaving on econ mode.
That's a symptom of the low speed resistor on the fan being burnt out. The fans pulse between high speed and off. By having the "Econ" button on, it disables the A/C and as such disables the low speed fan. You need to be careful as the pulsing can blow the fuse on top of the battery meaning the fans won't operate on high speed when needed, like being stuck in traffic.
With A/C on, "Econ off", the fans should rotate continuously on low speed.
With A/C off, "Econ on", the fans should be stationary.
When the coolant temperature reaches around 105 degrees, fans should run on high speed.
Reactions: ultimateauto
