1 - 8 of 8 Posts
Hi guys, right to get to the point, for some reason my MK5 R32, wont go into any gear.
The engine starts perfectly fine, no issues there. But when its on, I cant shift it to any gear at all, when holding the clutch down. It is not displaying anything on the dash,
But I can put it into gear and start it up, it drives on that sense, but then when running I cant shift it into any other gears.
Does anyone know what the issue could possibly be? It was perfectly fine yesterday.
Thanks, I really appreciate your time.
Discussion Starter · #2 ·
Also just to add, I think the clutch feels a little loose when I press it, or maybe its just me, but it dont feel the same.
transfer box? what exactly is that? and I mean I was told it could be a valve from the gear box or something like that. Is it fixable? I mean its unreal how it worked yesterday and not today!
Well it's basically a box that sends the power down to the front and the rear axle. To be fair I'm not even sure if the haldex system uses one. But it's a all wheel drive thing. Mine had basically come detached so nothing would work. Wouldn't even let me select a gear. Wasn't particularly cheap. I don't know a lot at all though sure someone else on here soon will know...
... Or call me a twonk because there's no transfer box on an R32 or something!
But the symptoms are identical!!!
Aha thanks
I understand. I was reading a little more into it, and I think that it may need a new clutch. mine seems very still and when I put it into gear and turn on the engine and try to release the clutch it make a sort of cracking noise.
Sounds like the clutch as collapsed mate or release bearings failed
1 - 8 of 8 Posts
