1 - 1 of 1 Posts
My mk5 r32’s shifter feels sloppy and there’s a fair bit of play up and down as well as left to right. Just to add to this, first gear engages when putting it in quick but seems to not want to go in when doing a slow gear change into first - looks like it gets blocked by something
I’ve been told the bushing for the shifter (metal piece under the airbox) has got some play which may contribute to this and I will be getting this changed.
question is, would this fix all the issues mentioned above or is it likely the bushings around the gator are also worn and need doing?
thanks
1 - 1 of 1 Posts
