1 - 2 of 2 Posts
Hi all,
Does anyone have access to a Mk5 rain/ light sensor removal guide? I'm having the windscreen replaced and want to remove as much as possible myself to limit the chances of damage!
Thanks in advance,
Paul
The new windscreen should come with the mount, its just a matter of separating the two plastic covers either side and it should slide out. Im pretty the sensor is on the bottom of the base of the rear view mirror, the bit you can see from the outside IIRC
1 - 2 of 2 Posts
