1 - 6 of 6 Posts
Admin
Well I don't really know about ECU's but I want to use a FIS controller and the engine if you plug VCDS in tells you what protocol the ECU uses....for the controller to work the engine module has to work on KWP1281 and mine is KWP2000 so I need to either see if mine can be changed...which I doubt or find a ECU which I can get which I can use in my car.
This is what I mean....
http://www.blafusel.de/bilder/obd2/vag-com.gif
1 - 6 of 6 Posts
