mkiv Headlights
1215 Views 6 Replies 4 Participants Last post by  maz32
last couple of days my drivers side headlight lens has been covered in lots of condensation,is the unit knackred ? as ithought they were sealed units.
And thanks wayne and others for providing a great site :beer:
All headlights are sealed....ish....the glass is bonded to the case but the backs are faily open to air etc...if you have got moisture in there it will condense on the glass....might be worth removing the headlight...take it inside....and place it in a dry warm place for a day or so after you have taken out the bulbs and back covers to let the air in and moisture out.....
Most modern xenon lights have dedicated breathers to allow for the temperature variation when switched on. Could possibly be a blocked vent, or maybe the seal around the glass has deteriorated.
its a pain to change the bulbs apparently so how easy is it to get the whole unit out ?
i didnt know that, nice one
unclip all the connectors on the back of the light.....and then 4 screws....two on the top of the light - slam panel and two screws under the light and she pops out....make sure the ignition is not on etc....
thanks for the info guys.had a look and theres some wires trapped where the power pack clips on ive freed those and hope that sorts it,as for the screws the top ones are easy but wheres the bottom ones ?
