1 - 6 of 6 Posts
HEEEEEEEEEEELLLLLLLLLLP!
Thats 235/35/19
Can get it right, they seem too low and manufacturers of tyres dont consider someone might swap the 18's.
ANy one else running 19's advise?
lower profile tyres require higher pressure. im running 35 front and 44 rear (psi) on 215/35/19's and the handling is great. best usually to check with whoever is making your tyre!
Spoons, I'm prob going 235/35/19 soon. How do you find the ride compared to the stock setup? In as much detail as possible please ;-)
I have 235/35/19 on my mkiv and I found the ride felt as good as if not better than standard.Make sure you go 235 though as this keeps the aspect ratio correct.I also think it depends what tyres you run.I have goodyear F1 gsd3 because I like how predictable they are in the wet.(which it always seems to be).PS just watch the big pot holes.
^^^^ the same tires, love them, very predictable. 2 weaknesses, a little shaky when cold, and also initial response to steering could be better. I am yet to see any tires coming close to these in rain, great handling on dry too
1 - 6 of 6 Posts
