1 - 14 of 14 Posts
.:R32OC Resident Pervert
Looks very nice Lee,
Whats is it like compaired to the R32 ?
The Audi is an awesome car i think it would be unfair to compare it to the r32.
The Golfs seats are more comfortable though and it was better on fuel!!!
Lee
I'd be scared stiff of doing anything like what you are doing to a car of that value. Can't wait to see the finished article, your R32 was stunning enough!
ok thought id post some pics on here of progress,
Boot installation with custom side panels
This shows the amp rack motorised up (Controlled from the key fob) this allows access to the Alpine EQ and the Battery
Side panel Routed ready for painted inserts to hold Nav and PG DD5
Sub box in the glovebox!! There will be a window in iside the glovebox so you can see the chasis of the speaker
Lee
Starting to come together now Lee should look very nice when done.
keep up the good work fella,
Stu
Not sure on the placement of the glovebox sub but then i aint an audio installer .
Rest is looking superb tho, great job so far. Keep the thread updated :five:
OK Boot Assembled for the first time,
Just to let you know whats left to be done, the two painted panels on the sides will hold the DD5 and Nav.
The Wiring that is running the system is tempory and was done for traxx and remain for the moment untill my custom RCAs turn up next week, then the DD5 will be fitted and the wiring in the boot completed properly. The car has been put together one as a trail to highlight any problems, and also is on a stand at a show this weekend.
other things to do are:
Get the Hu trim made in carbon to match the dash
Make Steel Grills and wrap in carbon again to match.
Few Trick bits over the winter, for next years Comps
Boot:
Pictures dont do the lighting justice ill try to get some when its dark!!!
Lee
1 - 14 of 14 Posts
