Hi guys im steve from norwich,i have a blue r32 mk4,having abit of a problem at the moment sometimes she wont start,had the crankshaft sensor done the other week but shes still doing the same thing,any recommendations as to the best mechanic in norfolk?????
You have probably seen this, change the temp sensor. I had this on an Audi and turned out to be temp sensor, after 30 turns of cranking the ECM automaticlly diagnoses G28 speed sensor
16706/P0322/000802 - Engine Speed Sensor (G28): No Signal
Possible Symptoms
  • Engine shuts off
  • Engine doesn't start
  • Speedometer inoperative
  • Glow Plug Indicator Lamp (K29) flashes
Possible Causes
  • Engine Speed Sensor (G28) loose
  • Engine Speed Sensor (G28) faulty
Possible Solutions
  • Check Engine Speed Sensor (G28)
Special Notes
  • The Engine Speed Sensor (G28) is also used as a reference sensor for the crankshaft position
Crank shaft sensor & temp sensor have both been changed,clive atthowe seems to think it could be ecu or the wiring to the crank sharft sensor,i dont know what else to do,thanks for that though.
