1 - 6 of 6 Posts
Hi
Does anybody know where i can pick up the mounting for the front numberplate. Mine seems to have snapped on one side so isn't sitting flush.
Or do you know if you can screw pressed plates into the bumper, as in are there holes already there?
Cheess
They are about £30 from vw but arent painted, or you can buy a mk5 gti holder that is the same for £7...
ahh great cheers, just got some pressed plates, so going to see if it will go streight into the bumper without the mount.
it will go on without the mount but wont look as good in my opinion
where did you get your plates made up? dubmeister?
Get pressed plates on ebay cheap as shit.
Also you can remove the surround and glue a magnet on the inside of the bumper and the plate will stick to the bumper then. No drilling required. All you need to do in time is get it filled and painted
I got them from early edition. I forget the stand name, theres a card somewhere. Look proper smart. Had to drill some new hole in the back casing to get it to sit abit higher as ive fitted led number plate lights and there were shining off a bit of body work showing so its nice and snug at the top with no body work showing.
1 - 6 of 6 Posts
