Thanks silver will give then a go! Plus theres 10% of them at min aswelThese...
http://www.autopartslights.com/volkswagen-vw-mk4-mk5-golf-gti-passat-led-license-plate-light-p-222.html?zenid=tim6ecg99g9jq4b8a91mqjpb86
Never had a prob. Loads of people have since bought them off here and nobody has ever moaned to me since so must be good/>
Silver I've had two sets of those and both sets started to flicker after a few months.These...
Ill have a look B4DVWThis is what you need buddy, not cheap but ver effective and OEM. Found on the Golf R and Rocco. 2 x 1K8 943 021 C
If you type that into eBay.de you find a few for sale
HTH
Random. Ive had mine for 2years now with no probsSilver I've had two sets of those and both sets started to flicker after a few months.
The picture sort of gives it away....U gotmk4 or mk5
Something away in the back of my mind says to me that to retrofit Golf R / Scirocco LED lamp assemblies you need to reverse the polarity at the connector. Sorry can't remember where I seen it though.Do the Golf R OEM ones fit the MK5 R? I presume its the same connections and size etc?
You are correct sir..Something away in the back of my mind says to me that to retrofit Golf R / Scirocco LED lamp assemblies you need to reverse the polarity at the connector. Sorry can't remember where I seen it though.
Can you enlighten me please?Which is really easy to do I just fitted mine on my MK4
