Hi guys started her up today and it sounds a lot louder than usual after getting my spark plugs changed the other day. Any ideas? Got a video I'll try upload on here...
MK4 or 5?
What plugs did you use? OEM?
Mj
It's more than likely nothing to do with the spark plug change, just coincidence.
Under certain conditions on start up the Secondary Air Injection (SAI) pump runs for a short period of time and while it's operating the noise level is louder than normal.
It could also be the radiator fans running on high speed due to a fault. Very common issue on the MK4 and not unknown on the MK5.
Thanks for the comments lads. Jusy done a bit more investigating and I reckon I've got a leak on my flexis on my exhaust somewhere. Problem is I can't Jack it up high enough to find it... Booked in at the garage tomorrow
Are you Jack Flanagan?
Mj
