1 - 12 of 12 Posts
Hi Guys,
Need some help with this, Yesterday I noticed my door handle blank cover was loose and I could just pull it off when opening the door which is now really bugging me, Now I've looked at it I reckon it seems something is missing cause I can see how it clicks or tightens back on I've removed the plastic clip on side of the front door and used a T20 on it to tighten it but that has being no help.
Any help please.
Ryan
Admin
you still have to take the door apart to fit it...you have to get the handle out so you might as well use the one thats fell off....it usually happens because people take the torx screw to far out when fitting the blank
Yeh its my retaining C - clip which has fell out I think, I'm guessing this is a full door card removal then. Roughly how long will this take to do if you know what you are doing, anyone?????
Admin
on that picture the clip is there.
Its a couple of hours at most if you are half decent with a spanner/screwdriver.
If you can get a Haynes manual for a MKIV it may show you how to do it.
Cheers, Yeh the clip was in earlier but I heard it fall to the bottom of the door tonight, gutted.
1 - 12 of 12 Posts
