Hi I've recently purchased a mk5 R32 and it seems to over heat alot, being in slow moving the car raced up to 130degrees and I've had to pull over to let it cool down is this a regular problem.??
Many thanks
Many thanks
If the fans were working you would hear them spinningOli-Gatley said:Thanks guys currently stuck in traffic on the edge of London, suspecting that the fans aren't working as temp drops as soon as I can get moving but rapidly heats up once stopped.!! Yay.!!
Also switch it off as soon as you hit traffic you don't want to cook the engineOli-Gatley said:Thanks guys currently stuck in traffic on the edge of London, suspecting that the fans aren't working as temp drops as soon as I can get moving but rapidly heats up once stopped.!! Yay.!!
Also, have the cabin temperature up as hot as you can stand to try and remove heat from the coolant passing through the heater matrix.Also switch it off as soon as you hit traffic you don't want to cook the engine
I used to have to do this years ago in my 5 turbo as they overheated with the fans workingcuprabob said:Also, have the cabin temperature up as hot as you can stand to try and remove heat from the coolant passing through the heater matrix.
I would investigate sooner rather than later as you don't want to warp the head.
X2 with the punto turbo.. Sat in traffic on a motorway when we used to get blazing red hot days.. All windows down and heaters on full whack..I used to have to do this years ago in my 5 turbo as they overheated with the fans working
Lollee_shep said:X2 with the punto turbo.. Sat in traffic on a motorway when we used to get blazing red hot days.. All windows down and heaters on full whack..
G12 plus plus or G13 from VAG dealers mixed 50:50 witb distilled water. It comes in 1.5 litre bottles and costs around £10.
