2007 5dr DSG RS R32
My Mk5 R32 has started throwing the above error codes and yesterday illuminated the check engine light. Anybody had experience with these codes or know common things I should be checking? The car still drives fine but does seem to stumble a bit on startups so it doesn't seem too serious.
01 Engine
System description: MOTRONIC ME7.1.1G
Software number: 022906032JR
Software version: 6773
Hardware number: 022906032GP
Serial number: VWZ7Z0G8004594
Coding: 0000178
Trouble codes:
P0171 - Fuel Trim,Bank1 System too Lean Upper limit exceeded
Intermittent
Priority: 0
Frequency counter: 8
Driving cycle: 255
Mileage: 139283 km
P0174 - Fuel Trim,Bank2 System too Lean Upper limit exceeded
Intermittent
Priority: 0
Frequency counter: 2
Driving cycle: 255
Mileage: 139392 km
P0441 - EVAP Emission Contr.Sys.Incorrect Purge Flow Lower limit not reached
Intermittent
Priority: 0
Frequency counter: 1
Driving cycle: 255
Mileage: 139399 km
Motor vehicle Automotive tire Font Vehicle Wheel
Does your exhaust system smell "off?" Like rotten eggs?
2007 5dr DSG RS R32
No, smells no different to normal.
Sent from my Samsung Smart Fridge
How are the plugs?
"When crank times increase due to worn-out ignition components, ie, spark plugs, fuel dilution of the oil causes fumes to collect in the intake and breather systems causing major adaptive requirements, and turning on the MIL...
As with most OBD II vehicles, fuel trim is influenced by inputs from the MAF sensor as well. Any leaks in the intake boot upstream of the MAF can adversely affect fuel mixture, again causing the MIL to illuminate...
But also take a look at the intake ducting itself. The boot is actually hard plastic and is often hardened and easily broken during air filter replacements..."
2007 5dr DSG RS R32
Plugs are only 15k (Kms) old. Intake is also fairly new and not damaged. Recently cleaned the MAF aswell. Can't see/hear any obvious leaks from hoses etc.
Car is due for a service this month so if it's not fixed by then it can be VWs problem.
