1 - 9 of 9 Posts
the little cover that goes on the bumper, as mine has fallen off
rough price it would cost?
would vw paint it as well?
cheers for replies
Not sure how vw work it left probablies means passenger side though
Left cover - 1J0 955 109 B
Right cover - 1J0 955 110 B
They come ready primed and they will paint it if you ask not sure on the cost really shouldn't be much really as not much paint is needed at all but you may find getting some paint in an aerosol and painting it yourself could be cheaper
Or you could try a wanted ad for one in your colour would work out a lot cheaper, give lucifer a PM
You could carbon or vinyl wrap yours if that's what your into, try painting it yourself. Pred might give you some DIY painting skills.
I doubt lucifer has any
Very rare colour then, just ask them to see how much it would cost to paint and then tell them you'll get back to them, come on here tell us how much and ill tell ya if its a good price but anything under 20 is probablies cheap maybe even 25 as they will more than likely be using waterbased base coats
Which isn't cheap exactly
Just to give you an idea of cost of a custom colour spray can is about 10 - 15 quid then a clearcoat is about 5 - 10
It wouldn't really need polishing up as its a small part and should get a decent finish with just spraying, you will probablies need to sand the primer with some 800 just in case and panel wipe it down before spraying
ok i shall put a reply back on here to let you know.
they should have paint code on their system?
Yeah they should but if not look at the sticker in your boot, it should overlap the spare wheel well and boot floor, get a picture and ill tell you your paint code
update:
i know someone who works at vw and i managed to get the part for £16.94 primed rather than £30 plus vat so happy days
as for painting it im gonna get my wheels refurbed and skirt sorted at same time at the bodyshop vw bury use.
1 - 9 of 9 Posts
