1 - 6 of 6 Posts
Hi guys, does anybody know what codes to change on a vw vas system, to make my multi function steering wheel buttons and multi function display work with my rns 510 i had fitted in my 09 mk 5 r32 the other day.My brother is a salesman at vw in norwich and is taking my car in to work tomorrow and hopefully getting technician to take a look on his lunch break, but i dont think either my brother or the technicians are to keen on the idea of changing codes they arent to sure about. if anybody has any ideas they would be much appreciated!
It does need some coding, cant remeber what 'bits' and numbers it is, but I did find it online when I had the same problem. I couldnt be bothered with the long coding at work, so took it to a car audio place near me and they done it on Vag Com.
I can do this, but you're miles away. Im in Hudds.
In VCDS:
Go to Module 17 (Gateway), go to installation list, make sure Navigation 37 is ticked.
Go to Can Gateway 19, in coding click long coding, tab across to Byte 4, click enable on Bit 6.
Save and exit. Job done.
P.s Don't mess it up.
1 - 6 of 6 Posts
