1 - 11 of 11 Posts
· Mozquito Member
As my R32 is up for sale I wanted to get a service done before it was sold.
So had it done by Awesome GTI today, and although it had a major service last year, it threw up the following:
NSF Tie Rod has play.
OSF Tie Rod has play.
Exhaust hitting heatsheild.
Undertray missing.
So, obviously the undertray, is this a standard MK4 tray I can get second hand on ebay etc?
The tie rod ends, I'm not fully sure what these are, would I be correct in assuming the below is correct, and they can be used for either OS and NS, so if i wanted to replace both, I should buy two?
http://www.eurocarparts.com/ecp/c/Volkswagen_Golf_3.2_2004/p/car-parts/suspension-and-steering/steering/track-rod-and-track-rod-end/?606440725&1&7419507a034ac23446cdd1c43ebebaba8f82a241&000347
I'm looking to get these bought myself and fitted by my mechanic afterwards.
Can anyone confirm if this is correct for the Tie Rods?
The exhaust hitting the heatsheild, what can be causing this?
If you mean track rods then that's the inner track arm (aka drumstick)
If you say outer track rod end you'll be looking at this (hope this link works
http://www.eurocarparts.com/mobile/ecp/c/Volkswagen_Golf_3.2_2004/p/car-parts/suspension-and-steering/steering/track-rod-and-track-rod-end/?606440385&1&f7b751edfd52219e27c10280ff89bb9d9cfbf1f5&000349
Or if your looking at track control arms you'll be looking at this
http://www.eurocarparts.com/mobile/ecp/c/Volkswagen_Golf_3.2_2004/p/car-parts/suspension-and-steering/suspension/suspension-arm-and-suspension-joints/?616441430&1&90276f62d16d326ae4c9a266c8418bb107b117c0&000320
Forgot to mention that tie arms are used on the rear of our cars not front
So maybe some terminology has got mixed up somewhere
You may wanna call them and confirm exactly what they mean or if there is another term for the parts
Or maybe on this rare occasion I am wrong?!?
*shock horror*
If they mention it extends from the steering rack inner or outer then it's either what you mentioned or what I put up first
If they say its from the subframe/chassis them its the second thing I said
Hope this helps :s
· Administrator
It's also called an inner rack end, it goes Inbetween the track rod end and rack, mine were changed last year after MOT advice
It can be a number of things so you need to connect it up to vagcom to see what error is coming up.
Could be;
Coilpacks (but car would be misfiring)
Coolant temperature Sensor
MAF
Lamda Probe
Check your brake lights as IIRC, if the brake pedal switch goes, it can also flag up the EPC light for some strange reason.
tis not like you to make a spelling mistake and be totally off with advice....
1 - 11 of 11 Posts
