1 - 15 of 15 Posts
Semi-Advanced Member
When I first bought my car I took it to get dyno'd it only pulled 220 when we unplugged the MAF it made 10bhp more, there were no lights or fault codes on the car
Just ordered a new MAF. After 65k miles it might just be time to replace it anyway.
So you made 220 > unplugged 230 > what was your figure with a new/clean MAF?
Unplugged the MAF and the check engine light came on right away. Is that normal? Was trying to see how it runs.
Yeah, that shows your mafs ok I would say
Doesn't show it's ok. Only that it didn't get a signal to the ecu. You have to do a MAF log to check if it's ok. Also at idle it should read around 3-4gms. As MAF sensors die they start to read too much air and so cause rich running.
Don't have a VCDS/VAG Com but I ordered an EML327 odb2 device so let's see what the iPhone can log.
But 65k miles and 3 aftermarket intakes ..... so I just ordered a new MAF sensor ($100) as I noticed I don't get that good of a mileage anymore (very slow decrease).
Discussion Starter · #13 ·
Just tried to log the car. Using OBD Fusion for the iPhone I got for the Mass Air Flow a maximum reading of 27.8 at 7100rpm .... is that good or bad?
1 - 15 of 15 Posts
