1 - 12 of 12 Posts
Just a quick one, im a tad confused on whether this is lowered as much as it will go or whether its on the highest setting...
heres a pic im sure someone will clear this up for me quickly...
Adam.
That's lowest.
To go any lower some people remove the purple adjuster completely, and just have the spring on it's own.
ad_182_uk said:
will maybe look into it in the future then, cheers.
As GTI FLY says removing the purple adjuster is common, I have removed the threaded part oy on mine for perfection :)
how would i go about removing the purple adjuster? would i need a spring compresser etc or is it as simple as just undoing it until the purple but it out?
Adam
As above, you can pry the spring out then, I took the purple bit out and left the rest in ha. As long as the spring seats ok you'll be fine :)
On my mkv I wound the purple adjuster down and it lowerd it more
1 - 12 of 12 Posts
