1 - 4 of 4 Posts
Special Member
Hi guys been looking for some new wheels for a while, just a quick question.. What offset can I get away with if I go for stock tyre size and 18 x 8 wheels? (Car is on H&R springs if this helps) hope you can give me a bit of advice :)
Special Member
Thanks Alex.. Looking for MK5 info tho
You don't want to go much lower than et40, the lower the ET number the further the wheel will stand off the hub. So this will make it all the more difficult if you need to run adapters. A set of 7.5's with an ET of 40 may just fit a mk5 if they were 5x112, but if they need adapters, an 8's or higher you would definitely be on the limit of arch fouling.
Hope that helps chap
1 - 4 of 4 Posts
