ok my r32 is burning oil plugs are black when i pull them out the piston rings were replaced about 5k ago when i built the engine due to bent con rod i did grind in valves at time but didn't do valve stem seals
i replaced the valve stem seals about a month ago but still when i pull out any of the plugs there is oil on piston im confident the oil is coming down from head
so im just asking anybody come across this problem
or have to replace valve guides
or ever come across head cracked around the plug i haven't taking head off since but planing on it soon just looking for someone to put me in the right direction thanks
there is oil on piston when cold and after driving
