coilovers bud. or is this normal to hear a creek/clunk?Shall I just fit coilovers? You on standard suspension aswel?
Where did you get yours chap? What's the tell tale signs if there knackerd?My poly ones creek but there not worn, bear it mind when you change them
Yeah that's what I'm experiencing. No harm in changing them to polyStandards-VW
Poly-PSi Tuning
They knock and creek pretty bad at low speeds and/or full lock
Says it lowers it a further 10mm? Be good if it didNah but they creek as standard, although there is nothing wrong with them
Yeah it does, only because they are 10mm smaller than the rubber onesSays it lowers it a further 10mm? Be good if it did![]()
Wouldnt be surprised fella, R32's munch top mounts for funim just getting the creaking, take it its the same thing?
Sweet. Getting ordered tomorrow. Cheers fellaYeah it does, only because they are 10mm smaller than the rubber ones
Mine creek like fuck and the bushes are all sound. Pretty commonI'd be amazed if an R32 has gone through a set of top mounts since Friday. Sounds to me like the problem lies elsewhere.
If anyone has knocking at low speeds then I'd suggest checking your Arb's for play first as its easy to do.
I've got poly mounts and not heard any creaking/>
