1 - 9 of 9 Posts
Hi all,
I have noticed a rattle from the rear passenger side of my R, did a bit of poking about and found that the brake disc shield is loose and causing the rattle.
Can these be replaced without removing the hub?? Don't really want to get new bearings just to replace the shields.
Does anyone know the part number for the splash shields also??
Sorry if this sounds daft, but have you tired tightening the bolts that hold it on? There are 3 in total. With a small spanner you can get at them, I've just removed the guard with upgrading to 300mm discs on the rear so had to cut these bolts as like you say the hub gets in the way!
1 - 9 of 9 Posts
