I managed to change the rear disc and pads on one side today, but on the other side i was unable to remove the lower nut holding the caliper bracket on, so i was unable to change the disc and decided to leave the pads for now, will this cause any issues untill some time next week when i can get to a garage ??
unless someone knows how to remove the nut, i was using the M14 bit but it did not fit properly in the bottom nut (think it was already threaded inside) i saw these on screw fix web site, dont know if they will help on the round outside of the nut http://www.screwfix.com/p/irwin-5-piece-bolt-grip-nut-remover-set/96028 ?
