1 - 6 of 6 Posts
I used to have the rcd300 and had a menu on the mfd, since installing the rns510 that's gone so I assume it needs coding also I've got the amp under the passenger seat so I assume that's needs coding to, then I've brought a fiscon basic plus and i know that needs coding, so the question is what bits on a vagcom do I need to change to aid the helpful person who ends up coding it for me! Is a mk5 56 by the way and have no idea on the canbus and its a 510 version b with new maps thanks
As its a version B you wont get any battery drain, but for coding assuming you have vagcom you need to go into navigation 37 and untick BAP save the coding then reboot the rns510 then you should get audio & navigation in the mfd. hope this helps
RNS510 Video in motion, V9 Maps, Speed Cameras, FW2760, FW3980, FW4020 FW4120 With Radio Text, R32 Boot Up Logo & Can Gateways £90 Coded
The fiscon should just work anyway i think but go into module 19 gateway and scroll down to near the bottom & tick 77 telephone then save the coding & exit
1 - 6 of 6 Posts
