I figured I'd move over the the correct spot for my Mods I'm doing on my R32. As you guys know I bought it at auction and I'm going through it. Decided while I've got her apart I'd buy some "go-fast" parts and do some mods to make her a bit faster. I'm installing Schrick 264 intake and exhaust cams, High flow cats from USP and an X-Force 3" Stainless cat back sys. Got the engine dropped out on Saturday afternoon in a couple of hours. It's easy. This evening I got the engine & trans split and pulled the valve cover & timing covers. Engine is pretty clean on the inside. It was well maintaned. I'm gonna need a thermostat housing (it was starting to leak a bit) and while I'm in there (because its a bitch to replace in the car if it leaks), I'm going to replace the "crack pipe". Just a good idea, I'd be half assed if I didn't. The dual mass flywheel feels a bit loose so I'm going to replace it as well.
