1 - 3 of 3 Posts
Hi and merry Christmas all members.... please can anyone help or advise best way to replace front side light bulb in headlight (501 bulb). Dint really wish to remove bumper.
If it's a MK4, then it'll be a H6W bulb for the sidelight, not a 501 bulb
IN terms of fitting, it's just a case of unclipping the headlight rear cover , rotate it 90 degrees out the way as best you can. As long as you can get to the sidelight wiring, you can gently tug on it with your finger tips and that should be enough to get the bulb out of the headlight
Sorry to Hijack the post. has anybody got a good source for some LED side lights?
I have seen the sidelights referred to H6W, BA9 and BA9s bulbs which one is it or are they all the same?
1 - 3 of 3 Posts
