UPDATED 29/04/14
Updated the price, now £50 cheaper!! Due to finding a better/easier way of removing the outer lens. Also, the LED's have been changed for brighter, wider units which look more like the OE outer light.
Still working on getting SMD LED's fitted correctly. Will update as i progress.
Hey, i'm offering my services to convert your current Valeo rear inner lights to accept LED's and give the skyline look.
I have already worked on Fernr32's lights, you can see his thread here
What happens is you either send or drop your rear lights in to me (just inners required), leave them with me and i send them back to you or you come and pick them up when ready. The process should take no longer than 2 working days (24 hours for the sealant to cure).
You also have the option to remove the red plastic fog lamp lens, as Fern did. This requires that a red bulb be used in it's place, preferably LED. The clear lens will be hot glued in place.
The price is£160 plus £8.80 £110, plus £8.80 insured return postage (if required)
Thanks to FernR32 for the photo's. More pictures to be added soon.
* I am currently testing out various other LED types including PLCC2/4 SMD LED's.
** Also, please note, i cannot be held responsible for any breakages to the rear lamps. Removing the lens cover is possibly the most difficult part of the conversion, and is the reason why most people do not attempt it. I have experience in removing lenses from both headlamps and rear lamps, and normally do not have any problem however.
UPDATED 29/04/14
The price is
