1 - 8 of 8 Posts
I went to use the mirror in the driver's size sun visor for the first time yesterday and got a bit of a shock as the glass was completely shattered! :angry:
I have no idea how long it has been like this, may have happened before I bought the car - not the first thing you think to check!
So has anyone had any experience of this?
Should be relatively simple to replace I guess? The only issue I have is that there must be some sort of wiring involved for the light to come on with the slider.
I reckon I might have to replace the whole thing rather than just the glass. Never done anything like this before - should be interesting! :dry:
Cheers,
Oh, totally not what you'd expect!
Not sure if the glass will be replacable, might be worth seeing if a local breakers has any?
Yeah - that was my first port of call this morning - to check first choice spares. I have had quotes from 26 - 36 quid inc. delivery. Doesnt seem too bad to me but I have never replaced a sunvisor before so nothing to compare against!
Does anyone know how the electrics are connected? Can anyone tell I am a complete novice when it comes to these things! lol :)
You will need the full visor, Mak did this a few weeks ago and it cost him about 60-100 quid new.
Scrappys your best option as its the same mirror across the range.
Simple to replace tho as its just plugged in.
Admin
i just removed mine and took some pictures for you..It's very easy to do
First remove the cap covering the screw
Next remove the screw
Then pull the visor towards the seat .Do this carefully
It will look like this when you have it out.Tug very gently on the red and black wires to get the plug out.
The plug should be covered by a foam protective layer.
This just slides off to reveal the plug.
Just unplug this and plug the new one in and reverse this process to refit the visor.
Hope this helps.
Can't ask for a better guide than that!!!
How good is this place when you need a hand!
Bloody Hell Paulie - thats awesome! Thank you all so much. This place is quality! :thumbup:
1 - 8 of 8 Posts
