1 - 3 of 3 Posts
Im going to have to solder a resister into my numberplate wire link to fit after market as ive tryed loads of bulb replacements and non work apparently puting a resister in will make them work how do i du this?
· Semi-Advanced Member
I wiered in a resistor to do the flapper solenoid delete, you just have to find the right wire, cut it, expose the ends and solder in your resistor, use a heat shrink to wrap it all up and then finish it off with insulating tape. Most important to get the correct resistor!!
· Flaccid Member
1 - 3 of 3 Posts
