spark plug change
3259 Views 1 Reply 2 Participants Last post by  Synchro
Hi guys iam looking to change my spark plugs this weekend does anyone know
how you remove the spark plug lead off the coil pack is it just a case of pulling the lead off,:unsure: your is there a special way of doing it
1 - 2 of 2 Posts
You have to unclip the snap connector off the top of the coil pack.I used a screw driver as you can't get a finger in,then carefully lever out the coil.VW use a special tool which hooks underneath it.The coil is tight as all the dirt goes down the hole and sticks it in.
1 - 2 of 2 Posts
