Hi Guys
What's the best type spark plug tool to get for the MK IV R32?
Something that is easy to use.
Also, in terms of replacing the spark plugs, are the "NGK Laser Iridium SPARK PLUGS", the best ones to go for?
Bernard,I use a 14mm thin wall plug socket.I just crack it with the t-bar and extension then I take off the T-bar and continue to undo by hand as to protect against the chance of cross-threading. I have been told VW made a tool to remove the coil packs with ease,by levering them up safely without damaging them.I use a pair of bent long-nose pliers.
As for plugs I have been told that the OEM ones are the best to use.
Toally agree with the above.
Reactions: JohnR32DUB
Thanks guys. I managed to remove the plugs quite easily now. I wanted to see the condition of them. They looked healthy. It may be worth hearing what are the recommended gaps (with the use of a feeler gauge) on the MK IV plugs that are needed.
