On the way home form Inters, i discovered a little problem.
The speedo doesn't go up smoothly......You accelerate from still it works ok until you hit 70-75.
Then once here it becomes notchy if you like, the best way to describe it it if you imagine a second hand on a clock, it goes up like that. the faster you accelerate the faster the needle like jumps if you get me.
When the speed slows its fine even under braking.
Its like as if its catching on something. No fault codes read any everything else on Instruments works perfect...
Suggestions please!!
