Morning all,
I've been looking around for decent remaps for my soon to be collected r32.....the car already has a miltek non res cat bak and an ITG panel filter. Could I go straight to a stage 2 revo map?
If so what gains could I see?
I'm thinking of using TSR performance in Bridgwater as I have used them before with my Polo gtd.
Cheers me dears
VAG4life
I thought it has performance exhaust and panel filter.....bit that's why I'm asking?!
I need some clarification
VAG4life
Semi-Advanced Member
Depends how much of the exhaust is updated as it comes in sections .... i.e manifolds, cats/decats, cat back. For a stage 2 you will need at least a decat/high flow cats to go with the miltek cat back. With a decent map you should see about 270bhp with similar torque, if you add manifolds you should see a bit more, but they are a pain to fit and pretty expensive
Cool cheers man that's the sorta info I was after, so basically smash some decay pipes on and get it mapped. Cheers pal
VAG4life
Basically yes, get them from lucifer off here as they are as good ad the miltek ones but half the price
