1 - 17 of 17 Posts
if it has the 3 mini iso's its possible to connect an external amp to it buy buying an amp pre out which has mini iso end then goes into 2 sets of rca's and had remote lead coming. cost about 15 quid
i know the mk4 can do it as i have an external amp :
which is a JL Audio 250/1 running a JL Audio 10w3, and a JL Audio 300/4 running 2 sets of JL Audio ZR650s all off the OEM Navi.
the iso is a sqaure yellow connector which is the middle of of the three next to the blue and green ones, and i have a spare if you want to buy it :)
Heres a pic of it.
Cheers antera309 have ordered 1
Loving the system pomme, just to confirm (lol) thats all off the standard sat nav head unit.
That connector does look very very nice, more functions then the one i have :(
Yeah its all run off the standard head unit, ie sat nav, which from the looks of your pics is the same.
thats the connector ive got one out of old car and think im going to keep it for when i want bit more base and sounds from the car
Pomme,
I've got a 4 channel amp and a sub which i want to run off my sat-nav unit, i take it that adaptor even tho its 6 channle would do the job ?
with that adaptor you can run 3 amps off it ie 3 rca leads going direct to each amp. a 4 channel amp will run 4 speakrs its not what goes into the amp. but the lead wil do the job you just wont use 2 sets of rca's outputs on the lead.
Ta gaz,
But by all accounts if i want to run a sub too, i'll have to use two channels fro front speakers and the other two to bridge for the sub ? At least this is what i've been told.
you going to run standard speakers off the 4 channel then a sub off another?
as gaz has said it all really depends on how you want ti to sound. I have one sub to run the 4 speakers and 4 tweeters and one to run the sub. Which i think would be the best way to go, and in each case both connectors would work, but i would get the one gaz posted on ebay :)
yeah ten i would get the lead daz said, and if you want to have better sound out the speakers in the future you can then easily wire them up :)
macdaddy said:
Pomme,
The kit I provided the link to takes feeds for channels 5 & 6 from the speaker connector by the looks of things. I wouldn't bother connecting these up. Just go with the 4 channels that come off the yellow multiplug. If you need to add a second amp later on, you can just use the RCA pass-through outputs on your existing 4 channel amp to provide the signal for it.
1 - 17 of 17 Posts
