1 - 2 of 2 Posts
Hello
Have been hunting around the web for a couple of hours but am struggling to find and info.
I think the stater motor on my mk4 r32 is on its way out, occasionally when starting from cold I hear a grinding noise for a half second, to me it sounds like the solenoid isnt fully engaging, but it does start and run normally.
Problem is I have no idea where the starter motor is, do I get access from the top or bottom, and what do I have to remove to get to it ?
cheers very much
If your looking down at your engine at the front of your gearbox (closest to the radiator) your see the starter moter easiest way follow the positve terminal from your battery down and on the other end will be your starter motor
Its only a few bolts and couple plugs and its out
If you need one i have one for sale
1 - 2 of 2 Posts
